I just spent the last three months chasing some noises in my daughter's MazdaSpeed Protege and wanted to collect all the information I found in one location. Since there are more Protege5 on the road today than other Proteges, I'm putting it in this forum and hopefully people can find when they search. If you find errors in what I've recorded or you want to add something below, let me know.
Here's the noise that developed:
https://youtu.be/BpR9q_vdqxo
Here's the noise after I went through this discovery process:
These Protege all use the same 2.0L FS-DE - Protege (DX, LX, ES), Protege5, MazdaSpeed Protege (adds a turbo obviously). They are solid lifter design using a Variable Tumble Control Solenoid (VTCS) intake. By this time (May2024), the majority of these cars are going to have 100K+ miles and often 200K+ miles. Add to that, the pricepoint means that many have deferred maintenance across multiple systems.
HOWEVER, the most common issue is a loud engine noise that could either be the dreaded connecting rod knock or valvetrain / lifter noise. Both sound similar, but obviously a rod knock means you need a new engine and a lifter noise requires some maintenance. Here is a troubleshooting process that I researched and found results with.
Let's start with what is and is not rod knock: rod knock is what happens when the connecting rod of a piston bends. A bent connecting rod is shorter and therefore the piston cannot make a complete compression stroke.
Rod Knock Symptoms
Metal shavings in oil
Louder on bottom end (and when listening from below the engine)
Constant noise AND occasional and uneven noises
Major changes in how vehicle drives; low on power, engine gets hotter, more noticeable smoke out the tailpipe
Faster since crankshaft spins twice as fast
Higher oil consumption (in the form of blue / grey smoke - smokes all the time)
Loud uneven clatter sound at startup
Overheating
Loss of compression + reduction in power/performance
A rod knock will only sound worse (louder) as the engine heats up. It will not go away as the engine gets warmer
Difficulty starting engine consistently
NOT rod knock symptoms / sounds
noisy lifters (especially hydraulic)
failing belt tensioner
Failed/failing knock sensor
Gets quieter after engine warms up
Consistent sound - like a metronome
crank or waterpump pulley contacting timing cover
Other frequently stated issues
Loud Injectors
Exhaust gasket leak
Spark plug noise
Knock sensor noise
Rod Knock Symptoms
Overheating
Loud Injectors
Exhaust gasket leak
Spark plug noise
Knock sensor noise
