Mazda of the Month - ENTER NOW for September!
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
NOTE: Please keep this thread ON TOPIC. Thank you and once again, good luck! (first)
DEADLINE to ENTER is September 25th '12!
Got feedback to help improve the MOTM?
Please click here and let us know!
Special Prize Announcement!
CR3 Motorsports is offering a $50 Gift Certificate to the
Mazda of the Month September 2012 Winner!
-Protege03ak46
-Adam
-2003 Protege LX
Suspension Mods:
-"Custom" Fortune Auto 500 Series Coilovers 6k/8k front/rear
-4-point 2012 SCCA/NASA approves roll bar, made with 1.5" x .120" DOM tubing
-Reinforced rear sub frame with custom bracing
-Racingbeat rear sway bar
-Front and Rear AAC End Links
-5-lug, 4 corner disc brake swap
-AAC Adjustable rear link kit v.2
Wheels, Tires and Brakes:
- 5Zigen FN01R-C White centers and polished lip.
Front:
-17x8 +25 with 205/40s
-~1.5 degrees of camber
-rolled fenders
Rear:
-17x9 +35 with 215/40s
-~2.5 degrees of camber
-rolled and pulled fenders
-Muteki lug nuts
-R1 Concepts slotted rotors
-Hawk HPS pads
-Corksport SS lines
-US Brake DOT4 600+ fluid
Exterior:
-Protege sedan front lip
-Bumper latches
-HID Headlights
-All red tails
-Hella Horns
-Camo vinyl fender
-GT-300 Fiberglass Rear Diffuser
Engine:
-Exedy Stage 1 Clutch
-CAI
-Ported and Polished Intake manifold with vcts delete
-AC delete
-2 1/4" Cat-back exhaust with bozo style tip
Interior:
-Megan Shifter
-3 inch extension
-CorkSport shifter bushings
-NissanParts shift knob
-aac Personal Steering Wheel
-Wink Mirror
-NRG bucket driver seat
-Orange RJS Racing 5-point harness
Herblenny
Phil
1993 Mazda RX-7 TwinTurbo Touring Edition
Engine:
-Pettit Polished AST
-Koyo N-Flow Radiator
-Custom Carbon Fiber Cooling panel
-Fast acting Airtemp sensor
-Remote Start/pager/alarm/turbo timer
-BNR Stage 3 Twin Turbos
-Ported 13B-REW engine
-Custom Grounding kit
-polished Efini-Y pipe
-Polished upper intake manifold
-Polished 90mm Rotary Works Throttle body
-Polished Greddy elbow w/injector ports
-Apexi GT Spec FMIC
-Custom polished pipings By: BNRSupercars.com
-Constant tension T-blot clamps for IC pipings and Intakes.
-HKS seq. BOV
-HKS twinpower ignition amp
-RE-Amemiya SS Dual Dolphin Tip Catback
-SS Pettit DP
-Apexi PowerFC
-Mazdaspeed ignition wires
-FEED oil filler cap
-FEED coolant filler cap
-Added R1 Dual oil coolers
-Braille light battery
-Braille Verticle mounting kit
-FC Datalogit
-Unorthodox Alternator pulley (red)
-Unorthodox Power steering pulley(blue)
-Exedy Hyper Single Clutch Kit
-Simplified seq twin set up
-polished hardline intake pipes for secondary intake.
-Ported JDM Upper Intake manifold and polished by David Garfinkle. Also all the misc. vacuum ports have been welded shut and clean up and polished for cleaner look.
-Pettit Racing water pump pulley
-2 x 4 blade fan set up for better cooling
-HKS RS intake with KN filters
-Tweakit Racing tensioner pulley kit
Suspension:
-M2 launch kit
-FEED coilovers
-Racing Beat sway bar brace
-Racing Beat sway bars (front and rear)
-Custom Garfinkle Motorworks Engine torque brace to clear Tower brace
-AutoEXE front brace
-RZ larger front and rear brake calipers
-Hawk HP+ pads front and rear
-Newly sandblasted A-arms and other suspension parts
-Custom Garfinkle Motorwork cross drilled RZ rotors
-Braided SS brake lines
-Racing Beat sway bushings
-New Delrin bushings for all suspension parts
-Transmission brace
-AutoEXE rear brace
-Dragon's diff brace
-WORK CR Ultimate 18x9.5 Front and 18x10.5 Rear
-Custom Carbon Fiber centers for the WORK wheels.
-Toyo R888s 255/35 front 295/30 rear
Interior & Stereo:
-Converted Black interior - including, door panels, rear panels, head liner, seat belts, and black main carpet
-RZ floormats
-Rare moon roof interior cover
-JDM rear seats with panels, seat belts, and special rear carpet
-added R1 rear speaker pods for 7 speaker system
-Prosport boost, A/F, Fuel, Boost, and Oil temp gauges
-Prosport center speaker pod
-Spirit R, Recaro Carbon Kevlar seats (1:1500)
-Nardi shift knob
-red leather stitching shift and ebrake boots
-LED interior lights
-Rare red stitch Nardi wheels
-Custom install of Protege cruise control to the Nardi wheel
-RE steering column pod with 52mm Prosport boost gauge
-JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (not overlay)
-JVC 7inch AV system
-New EL PowerFC commander and Gotham Racing PFC Commander holder
-RE-A speedo cluster gauge
-FEED Carbon fiber rear trunk add on.
-Base model hatch cover
-added OEM fog light switch to turn FEED HID driving lights
-Carbon look oem door step
Exterior:
-One off Feed Carbon Gas door (Shine Auto)
-Feed Type 2R front bumper
-Feed Carbon fiber canards
-Feed Carbon Fiber side skirts
-Feed wide front fenders
-FEED rear wide flares
-Rotary Extreme hood dampers
-R-magic oil cooler ducts
-FEED front tow hook
-RE-Amemiya Carbon rear diffuser
-Carbon Fiber rear hatch with FAL lexan glass
-Custom LED tail lights
-Custom rear bumper CF signal covers
-FEED head light cover
-rare glass moon roof
-SportTuner HID projector head lights
-LED signal lights in FEED signals
-HID FEED Signal lights
-Spirit R fender badges
-Efini front are rear badges
-Carbon look rear bumper lights
-Carbon fiber FEED gas door (one off made)
-APR Carbon Fiber side Mirrors
-Custom front canard add on
-Carbon Cooling panel (custom, made by me)
-LED Front bumper strips
-FEED signal light covers
-FEED door handles
-Carbon Fiber back of the door handle covers.
-Back Off 3rd light flasher
-ShineAuto rear tail light lip
-Feed carbon Fiber bumper guard by Shine Auto
Engine Bay Pic
Interior shot
Exterior pic
subs.
love the no battery in the engine bay for protege must do the same :)
and right above me ^ wow sexyy
Infamouszoltan
Zachary
2008 Mazda 3i
Exterior:
Stock Mazdaspeed 6 Wheels
215/40/18 Hankook v12
Custom Teal Paint on Axela Badge
Black Mazda Trunk Emblem(other badges removed)
35% Front, 5% Rear Window Tint
Spray Tinted Reflectors
Blacked Fog Light Housings
Open Mouth Mesh Grill
Lip Trunk Spoiler
Axela Rear Window Spoiler
Rub Rails Removed
Stubby Antenna
Rokblokz Mud Flaps
Interior:
Mazdaspeed Floor Mats
Dashboard Gauge Pod
Custom Teal Paint on Intercooler Pipes
Electronic:
6000k HIDs
Prosport Oil Pressure Gauge
Prosport Boost Gauge
Prosport Wideband Air/Fuel Gauge
Audio:
Ported XXX Sub Box
Two 12 inch XXX Speakers
1200 Watt XXX Amplifier
Performance:
Garrett T25 Ball Bearing Turbo
Turbo Specialties Front Mounted Intercooler
Custom Made SRI
Custom Made Down pipe
Custom Made Intercooler Piping
Option Racing Front Strut Bar
Turbosmart Dual Port BOV
Apexi Turbo Timer
Walbro 255 Fuel Pump
Eibach Sportlines Lowering Springs
-2Nine
- Ian Harrison
- Mazdaspeed3 08
IMG_6452 by 2Nine Photography, on Flickr
IMG_6455 by 2Nine Photography, on Flickr
IMG_6474 by 2Nine Photography, on Flickr
Exterior
-20% Tint
-Buddy Club P-1 Racing SF 18x7.5 +46
(Bronze Painted w/ white lettering on tires)
-5zigen Lugnuts
-06-07 STI front lip
-Yellow Fog overlays
-Sticker mod
-Short antenna
Suspension
-RaceLand Coilover's v.2
Performance
-COBB SRI
-TurboSmart Dual-port BOV
-SURE RMM
-Corksport Cold Air Box
-Street Unit Testpipe
-RES Delete
Hey 2nine question where did u get ur tires with the white writing or did u do that and also props its a sick car
Status
