***** Moderator edit: The most recent update at this time is 74.00.324A. Please review the link below for update instructions, and note that Mazdas247 does not assume responsibility of the actions taken by its members or the damages that may result from those actions.
							 mazdas247.com
					mazdas247.com
On another note, because other forum members may be willing to provide these links to help the Community, we want to provide fair warning to members choosing to use the links provided. It is important that you remain vigilant in protecting yourself from malicious links and software. If you are unsure about a link, do not click on it. If you have a virus scanner, use it. If it seems fishy, trust your gut.
In addition, keep in mind that while members want to help out by providing firmware links and instructions, those members may not be able to offer any other support past providing the links.
Looks like there’s a new firmware, anyone try it yet?
74.00.230A
Changelog
***** MAZDA Firmware ALERT *****
from JUN 01, 2021
MAZDA (MZD) CONNECT, WHAT FIRMWARE DO I INSTALL..?
FOLLOW the .PDF INSTALLATION INSTRUCTIONS 100%.
'.up' Firmware used for All MAZDA-MZD CONNECT MODELS 2014-2021.
**NOT For first production CX-5 or Mazda 6 with TomTom Navigation**.
*NOT For MAZDA CX-30 or MX-30 or MAZDA 3 (BP) see the
"CONNECT II 2019~" Folder for their own '.kwi' firmware*.
***NOT For 2021 MAZDA CX-5 (KF) or MAZDA CX-9 (TC) see the
"CONNECT 1.5 from 2021~" Folder for their own 'kwi' firmware***.
BEFORE you START, Switch CAR OFF,
Then Remove Navigation 'SD Card' and
LEAVE the SD Card OUT of the Car until
the FINAL File is Installed.
Then Car OFF again, then Insert SD Card.
Then start car.
Navigation will work as normal when using CONNECT.
1. Your FIRST Install Procedure...
IF YOUR MAZDA has old FIRMWARE VERSION ON or BELOW 30.00.000
LIKE 23.00.000 or 25.00.150 or 28.00.300 or 29.00.100C
THEN YOU *MUST* UPDATE with Version Number 31.00.100A FIRST.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
31.00.100A-FAILSAFE.UP (First)
Then next Install
31.00.100A-REINSTALL.UP
Warning...!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL RUN YOUR ''CONNECT'' IN CAR FOR
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE NEXT VERSION
TO INSTALL.
2. Your NEXT Install Procedure...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW 59.00.560A
LIKE 31.00.100A or 41.00.000 or 51.00.351 or
55.00.650 or 56.00.513 or 59.00.502A
THEN YOU *MUST* UPDATE with Verion Number 70.00.100A FIRST.
70.00.100A-FAILSAFE.UP (First)
Then Install
70.00.100A-REINSTALL.UP
Warning...!
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION
TO INSTALL.
3. Your FINAL Install Procedure is ONLY 1 (one) File now...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or ABOVE 70.00.021A
LIKE 70.00.100A or 70.00.110 or or 70.00.150A or 70.00.335C or 70.00.367A
THEN YOU UPDATE to 74.00.230A for the LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY, MUST USE EITHER ONE of...
NA N_74.00.230A-UPDATE.UP (North America ONLY)
or
EU N_70.00.367A-UPDATE.UP (Europe/UK)
or
4A N_70.00.367A-UPDATE.UP (ADR, AU. NZ, ME, Asia)
THIS IS THE LATEST FIRMWARE CURRENTLY AVAILABLE.
INSTALLATION AS PER INSTRUCTIONS IN SERVER
''MAZDA FIRMWARE UPDATE PROCEDURE WORLDWIDE'' .Pdf
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
More Information on How to get CP/AA Working Do the Following..
OPEN THE ''-CARPLAY-ANDROIDAUTO INSTALL'' FOLDER IN
THIS SERVER ON HOW TO DO THE GENUINE CONVERSION.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...NONE, SO DO NOT ASK.
YOU MUST PURCHASE AND INSTALL THE TWO GENUINE MAZDA PARTS, LAST.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
PACKAGE AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
WCP or Wireless Car Play is included in all 74.00.xxxx Firmware, BUT
You MUST aslo use a new 2021 CMU meant for WCP use price is over $999 USD.
If 74.00.230A is not in this Server for your Region it means a copy is not yet available
for Your Region or Country in the wild, yet.
			Guide: - Mazda Firmware Update Information
PLEASE READ THE POST IN ITS ENTIRETY BEFORE POSTING A REPLY IN THIS THREAD.  IMPORTANT NOTE: These files and processes are compiled from third party sources. Please be aware of the risks of performing these updates yourself. There is potential to brick your CMU if some steps are missed or the...
74.00.230A
Changelog
from JUN 01, 2021
Then start car.
Then next Install
Warning...!
A FEW MINUTES,
TO INSTALL.
Then Install
Warning...!
A FEW MINUTES,
TO INSTALL.
or
or
