Mazda Connect Firmware 74.00.230A (now .324A)
Status
Not open for further replies.
2019 Mazda CX-9 Signature, Machine Grey Metallic
***** Moderator edit: The most recent update at this time is 74.00.324A. Please review the link below for update instructions, and note that Mazdas247 does not assume responsibility of the actions taken by its members or the damages that may result from those actions.
On another note, because other forum members may be willing to provide these links to help the Community, we want to provide fair warning to members choosing to use the links provided. It is important that you remain vigilant in protecting yourself from malicious links and software. If you are unsure about a link, do not click on it. If you have a virus scanner, use it. If it seems fishy, trust your gut.
In addition, keep in mind that while members want to help out by providing firmware links and instructions, those members may not be able to offer any other support past providing the links.
Looks like there’s a new firmware, anyone try it yet?
74.00.230A
Changelog
***** MAZDA Firmware ALERT *****
from JUN 01, 2021
MAZDA (MZD) CONNECT, WHAT FIRMWARE DO I INSTALL..?
FOLLOW the .PDF INSTALLATION INSTRUCTIONS 100%.
'.up' Firmware used for All MAZDA-MZD CONNECT MODELS 2014-2021.
**NOT For first production CX-5 or Mazda 6 with TomTom Navigation**.
*NOT For MAZDA CX-30 or MX-30 or MAZDA 3 (BP) see the
"CONNECT II 2019~" Folder for their own '.kwi' firmware*.
***NOT For 2021 MAZDA CX-5 (KF) or MAZDA CX-9 (TC) see the
"CONNECT 1.5 from 2021~" Folder for their own 'kwi' firmware***.
BEFORE you START, Switch CAR OFF,
Then Remove Navigation 'SD Card' and
LEAVE the SD Card OUT of the Car until
the FINAL File is Installed.
Then Car OFF again, then Insert SD Card.
Then start car.
Navigation will work as normal when using CONNECT.
1. Your FIRST Install Procedure...
IF YOUR MAZDA has old FIRMWARE VERSION ON or BELOW 30.00.000
LIKE 23.00.000 or 25.00.150 or 28.00.300 or 29.00.100C
THEN YOU *MUST* UPDATE with Version Number 31.00.100A FIRST.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
31.00.100A-FAILSAFE.UP (First)
Then next Install
31.00.100A-REINSTALL.UP
Warning...!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL RUN YOUR ''CONNECT'' IN CAR FOR
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE NEXT VERSION
TO INSTALL.
2. Your NEXT Install Procedure...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW 59.00.560A
LIKE 31.00.100A or 41.00.000 or 51.00.351 or
55.00.650 or 56.00.513 or 59.00.502A
THEN YOU *MUST* UPDATE with Verion Number 70.00.100A FIRST.
70.00.100A-FAILSAFE.UP (First)
Then Install
70.00.100A-REINSTALL.UP
Warning...!
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION
TO INSTALL.
3. Your FINAL Install Procedure is ONLY 1 (one) File now...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or ABOVE 70.00.021A
LIKE 70.00.100A or 70.00.110 or or 70.00.150A or 70.00.335C or 70.00.367A
THEN YOU UPDATE to 74.00.230A for the LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY, MUST USE EITHER ONE of...
NA N_74.00.230A-UPDATE.UP (North America ONLY)
or
EU N_70.00.367A-UPDATE.UP (Europe/UK)
or
4A N_70.00.367A-UPDATE.UP (ADR, AU. NZ, ME, Asia)
THIS IS THE LATEST FIRMWARE CURRENTLY AVAILABLE.
INSTALLATION AS PER INSTRUCTIONS IN SERVER
''MAZDA FIRMWARE UPDATE PROCEDURE WORLDWIDE'' .Pdf
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
More Information on How to get CP/AA Working Do the Following..
OPEN THE ''-CARPLAY-ANDROIDAUTO INSTALL'' FOLDER IN
THIS SERVER ON HOW TO DO THE GENUINE CONVERSION.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...NONE, SO DO NOT ASK.
YOU MUST PURCHASE AND INSTALL THE TWO GENUINE MAZDA PARTS, LAST.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
PACKAGE AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
WCP or Wireless Car Play is included in all 74.00.xxxx Firmware, BUT
You MUST aslo use a new 2021 CMU meant for WCP use price is over $999 USD.
If 74.00.230A is not in this Server for your Region it means a copy is not yet available
for Your Region or Country in the wild, yet.
Installed it a few days ago. All is working for me and had no issues during install
With previous FW 70.xx I had an intermittent issue with Android phone detection via USB cable.
Now it seems to be working fine.
I haven't seen any new features, as there was no changelog (your link does not work).
(2019 CX-9)
Thanks for letting me know. It seems that all the links are not working. I even tried the URL for the 70.00.367A and it won't render ATM.
This was the URL for the Mazda firmware: HiDrive
As mazdacat mentioned above, the download file is not available at HIDrive. Hopefully this is a temporary problem.
Looks like this link is dead now too, anyone have a link to a new firmware? I'm stuck on 70.00.xxx and would love to upgrade to get CarPlay activated.
It doesn't look like ASH8 is going to continue the updates either. I have been lurking the Mazda3 Revolution post which links this. I have been using it to update my infotainment, which uses the same infotainment firmware as the CX-30. I was updating as files get posted.
I have a Mazda CX-9 2019 gsl. I want to know if I need to replace the usb hub, the dealer refuses to update my firmware. I cannot find the updated version. I was in 70.00.367A. Can someone send me the file for N_74.00.230A update version?
Is anyone able to send me this update? Finally saved up enough for the OEM CarPlay upgrade to install myself, but need to update firmware ….
Thank you in advance!
Hi, I recently got a mazda CX 5 which is currently running on a 70.0.0.XXX firmware and I would like to upgrade this. I would really appreciate it if someone could privately share the NA N_74.00.230A-UPDATE.UP file with me. Thanks in advance.
I would also like to update to NA N 74.00.230A if someone happens to have the file on hand and would be willing to share. Thanks
Hi. Newbie here from Australia. Just got a secondhand CX-5 with firmware version 59.00.545 4A N. I've bought the OEM hardware for Carplay/AA, but can't find the firmware I need. I understand I'd have to install 4A N 70.00.100A-FAILSAFE.UP then 4A N70.00.100A-REINSTALL.UP before I could then install one of the newer single file installations (about 4A N_70.00.367A-UPDATE.UP for my region, I think). Anyone got working links for these, or able to share would be hugely appreciated.
Would also very much appreciate a link to the new firmware. I'm sure the dealer charge to have them do it will be ridiculous.
74.00.230A
Changelog
from JUN 01, 2021
Then start car.
Then next Install
Warning...!
A FEW MINUTES,
TO INSTALL.
Then Install
Warning...!
A FEW MINUTES,
TO INSTALL.
or
or
###can you please provide me link for New firmware thanks.
Status
