Mazda 323 1.3L jacking on gear 1, 2 and 3…Help
I don't knw how to explain for you to understand.
My 323 is jacking on gear 1,2 and 3..
It does like I can't drive..the way it jack and I can tell it's not a misfire..
When you driving on gear 1 for the car to not jack ...it's either you put Gass on your fit a litle or you clutch it..if not it will jack jack jack jack jack and shut down..but if you clutch fast while it jack jack jack it doesn't shut down.
If I want to relax driving with a low speed it's either i put neutral on gear or I keep clutching to avoid the jack..
