It aint the prettiest fix, but I think it works so far. Like many owners I had a very annoying "tick tick, tick tick tick, tick tick" noise in my driver side door when driving along. It didn't only happen on bumps and was very annoying. Happened most often when the moonroof was open, or when turning left. If I put even the smallest pressure on the door panel it would stop.
Spent today trying to track it down. I thought I had found it twice, one with a piece of the backing making a noise when I pressed it, and another when I found one of the plastic locating pins to make a noise when I moved it. I stopped both, but the noise remained! Then I got fed up. I thought that perhaps the noise was the two styrofoam pads touching the plastic water barrier. So I took a detailing towel I had laying around and layed it over those pieces on the inside of the door panel. Put the door panel on and the pressure kept it in place. Buttoned it back and and took a test drive. I think it's gone! I am going to take a longer drive tonight to be sure.
Here is a picture of the location I placed the towel on the back of the door panel.
