In coming up with a more "permanent" solution to the PCV issue, I went shopping for fittings at the local shop today. When combined with Sig's sealed catch can, I should have an airtight path for the blowby to flow and collect. The "suction" side of the PCV system will be relocated to its own bung in the intake manifold, and the two top nipples will be capped. They simply don't flow enough for my new setup. -8 AN lines will be used in the whole system. Once the system is complete, air will be drawn in from a breather in the side of the valve cover, through the passages and baffles inside the valve cover, down through the crankcase, and then drawn up and out of the cover through the main bung in the center. If you don't know how the stock PCV system functions, read up on it. If you do, that should have made perfect sense.
Originally, I wanted to just tap and thread in a 1/2"NPT to -8 connector into the valve cover. As you can see, because of the hex head, contact will be made with the cover, and it is not pissible to thread it in all the way. I had thought about grinding the cover down for clearance, but there just isn't enough "meat" on the cover there to make me feel comfortable. So, onto plan B.
As you can see, with the nut "squared up" clearance is had.
I purchased a -8 Union fitting, with a bulkhead nut:
I enlarged the hole very slightly, and dropped the union through. In order the thread the nut on the backside, I had to clearance it just a C-hair:
To ensure a seal, I used a rubber washer on each side of the valve cover:
its' VERY hard to see, but look closely. I filled the compartment with water to test for leaks. The rubber washers work great, and no leaks were found!
The union end is FAR too long to fit under the internal cover, so I just ground it off, leaving enough to have decent threads, but not to much so as to impede flow, or sit in any liquid oil thats trapped in the baffles.
What the finished bung looks like on the top side:
I removed the bung again, and got to sandblasting stuff. Crushed walnut shells work great on aluminum. Before:
After:
Was able to fill some imperfections with some high temp epoxy. I didn't take pics, but I sanded and primed this after and it turned out great!
Painted the windage tray after I gave it a good sandblasting:
Painted my coil bracket:
Got to cleaning all the nuts and bolts. Believe me when I say that tedious does not describe this task! All bolts were run through the die, and wire brushed after being soaked in solvent. Before:
After:
Coils installed in the bracket:
My parts table. Everything is bagged or in containers, labeled and clean. I've got about 4 more boxes under the table:
What I'll be using for engine sealant. Permatex grey is the best on the market in my opinion, and is the very stuff Mazda used on your car at the factory. This stuff ain't cheap, it's about twice the cost of the black stuff, but in my experience it dries a lot harder, and is easier to apply:
That's it for tonight!
