max camber with CS struts
eyeballs
2012 Mazda 2 Touring SG 5MT
I'm curious to see what the max camber settings (for left and right) you guys are getting, and what bolts you are using to get them.
Today my specs were -2.3L -1.6R (no driver). Toe was set to zero. Racing beat springs and H&R camber bolts. Unfortunately I was not present for the alignment so I do not know how the specs would have changed with some weight in the drivers seat.
I was surprised to see that much of a difference, and it has me questioning whether or not the right side slipped on me while I was tightening the bolts. Anyone else running these struts have that much of a difference (from left to right) in max camber?
I would check the back of the knuckle to see if the casting is limiting the amount of distance the strut can move for camber. Our B-Spec car was way off on one side -2.5 for one side and -1.1 for the order max. We did a little grinding on the knuckle to remove the contact point and gained the camber back.
-Derrick
-Derrick
Thanks, that's got to be it. I feel alot better now about the -1.6 degrees. -1.1 is beyond disappointing.
