yes it can be done, however you may as well sell the car you have and buy a manual equipped car.
you need the g-series trans, all the hydraulic lines, clutch pedal, linkages, of course a different shifter, and the ecu for a manual 2.0.
Ummmm no....u can go from auto to manual for very cheap
I have done this
I have too. Im a mazda technician. I've done things you've never heard of with cars.
like i said....the g series trans, clutch pedal, linkages, shifter assembly, ecu. If you think you can use an auto ecu and auto linkages, you're on crack. you should probably set your wrench down.
UMMM....I hope that was not directed at me? First off I never got into detail so I'm not exactly sure where you got "If you think you can use an auto ecu and auto linkages, you're on crack. you should probably set your wrench down.".....but anyways, contrary to what a lot of "technicians" say this can be done on the cheeeep. Take it from some who HAS DONE this personally. I even drove the car with the AUTO ecu!!...word! Drove for 3months until I went with MICROTECH. And if you think "technicians" are knowlegable about cars.....take your car to ANY technician, I bet they leave s*** for you to fix.....so ya. Search this forum, I bet you can get EVERYTHING you need on the CHEEP!!! ( FACT)
A G series transmission can be had for less than $100... I actually just bought one for $50 and know where two others are for $75. Outside of that, you'd need an engine harness for a MT car (just bought one for $65 shipped three months ago) and ECU (which go for $100 or less on here, not to mention local salvage yards, and lines/master/slave assembly can probably be had for less than $100 at a local salvage yard if they're even that much.) Pedal sets are $25 at my local pull a part. Cluster will also be different I'm sure. I've never personally swapped over a Protg, but other manufacturers will require a different cluster for a complete swap, but, again, those can be had for $50. I'd say the clutch set (assuming you bought it new) would be the most expensive part of the swap.
And, let's not use the rubber hydraulic line for this, let's opt for a braided line since it's "the worst idea in history" and go baller status with a unit from CR3 for $40... Wow, the insanity...
well obviously nobody taught you what the word "simile" means. both topics i brought up are completely valid and show how swapping a mtx into a protege is as useless as buying used tires. now you're going to tell me that everything can ALWAYS be done for cheap? Ill be waiting on a thread from one of you that says "swapped my atx for mtx, something's wrong"
Been done....read my earlier post, mine drove trouble free, I'm saying it can be done for cheap,and maybe that's a relative term but he does not have to trade his car in and all that jazz. Come on now we not trying to reinvent the wheel,ppl.been doin this from since BEFORE you ever became a "technician"...have you seen the cost of parts for a protege lately?
