Manual Transmission Shifting Issues
pdexta
2015 CX5 Manual
I've been fighting some shifting issues with my 200k mile 2015 Manual CX5. It started with shifter movement with changes in acceleration and notchy gears and has been getting worse. It's totally out of commission now, I haven't been able to get it in reverse, 2nd or 4th at all now (this varies, at times it won't go in 1st/3rd, but reverse is consistently an issue). When cold, if I depress the clutch while in neutral the car will start to inch forward as if it's in gear.
Done:
Replaced all motor mounts
Replaced Trans Fluid
Bled clutch and verified slave movement (hydraulics seem to be working fine)
Checked shift linkage and bushings, all good
Disconnected linkage at transmission and I still can't manually put the car in 2nd/4th (I can feel the gate, but it won't drop in gear)
If anyone has any experience with this, or has any suggestions to look at please let me know. I'm assuming the transmission needs to come out at this point, hoping it's just a clutch, but the clutch has never slipped and I hate to just keep throwing money at it. Are these manual transmissions pretty robust or known to have issues? Thanks for the help!
Thanks for the input, I've been trying to convince myself it's clutch issue, even though I'm scared it's not. I ordered a clutch kit and I'm going to pull the transmission and see what it looks like.
The above leads me to believe that problem is internal to transmission rather than the clutch.
Right. As quoted below:
My suggestion would be to get a reputable and trusted mechanic to inspect it before you continue throwing time and money at this car.
I reluctantly agree, just grasping for hope I guess. Thank you.
Unfortunately that type of job with a mechanic is going to cost close to what the car is worth. I can handle the work myself, I'm just not too familiar with the platform and wanted to see if anyone had experienced something similar, or had tips on things to look for. If I pull the transmission and it still won't go into gear I'll hunt up a used one to swap in.
If it's not going into certain gears, I don't see how the clutch is related.
You should get this to someone who deals with manual gearboxes first. The right person will lead you to the actual issue far more economically than throwing parts at it.
I appreciate the feedback here, just wanted to give an update.
I pulled the transmission (I had to drop the subframe to get it out) and it still wouldn't shift into 1st or 6th. I found a junkyard in Canada with a used manual that shipped it to Tennessee for $600 and I'm back on the road. My old transmission would pop out of 6th occasionally, so hopefully that issue is gone as well.
I'm late to the party but I think that was the right call all along. If the transmission isn't moving, and the shifter cables aren't broke, then it had to be something inside the gearbox. Glad you got it working again and thanks for updating your thread with a resolution.
If you search around the interwebs, you'll see that this has happened to others with the Skyactiv manual. I've personally seen it happen at much lower mileage than yours - 2016 3GT with ~110k miles mysteriously started popping out of 6th gear and a few months later ended up towed home completely stuck in 5th. Same fix as yours: salvage transmission installed.
It does make me a little nervous considering I have two cars in the driveway with that same Skyactiv 6M 😨
That's super interesting. I have a 2015 Mazda6 with the 6MT as well (just under 100k miles) and have never had any issues, but I am curious if anyone's done a post-mortem and opened up their gearbox?
We had a Scion tC which at maybe 125k miles, we lost 5th gear. It would shift into all the other gears except 5th and sounded funny. I was able to pull the end cover off, exposing 5th gear, and discovered that the nut on the end of the output shaft had literally come loose. I tightened it up and put it back together and it never troubled me again.
For the example in my previous post, yes, my coworker requested that he get his old unit back once the replacement was in.
See here: https://static.nhtsa.gov/odi/tsbs/2015/SB-10105629-2532.pdf
At the bottom of the diagram on page 5, there's an exploded view of the 5th/6th gear assembly. The parts in detail "F" show the ring/hub that moves back and forth to engage either 5th or 6th. The outer hub ring slides one way to engage 5th, and slides the other way to engage 6th. The 3 little pawls shown are spring-loaded and hold the outer hub ring in whichever gear is selected.
Upon inspection, that hub assembly looked like it had suffered from misalignent for quite some time - the hub ring slid much further toward 5th gear than it did toward 6th, and the wear patterns showed that. I don't know why this happened, whether the previous owner bent the shift fork by shifting too hard, or a factory defect, or something else.
This unfortunately explains both symptoms he was having. 6th simply wasn't engaging fully, which is why it would occasionally pop out. However, 5th gear was over-engaged to a point where the 3 little spring-loaded pawls had room to over-extend their travel. At some point, with 5th gear engaged, one or more of those pawls was extended far enough where they actually prevented the hub ring from sliding *away* from 5th. Having the trans apart and physically sliding the hub ring back and forth, you could feel and see that 6th was only just barely engaged past the syncronizer teeth, just enough where you could actually use 6th. If you put it in 5th, you literally needed to reach in and retract the pawls on the hub with your fingers for it to let you disengage 5th.
Hopefully this wasn't confusing as hell, as it's easy to see with the parts in-hand, but not so much when you're trying to explain it all in a bloated post. All that matters is the car is back in service (and has been for the past 3 years), being well-loved by a former lifelong Toyota owner turned Mazda lover 😆
The STB clears my year and model. Part of the 2015 year might be involved.
APPLICABLE MODEL(S)NINS
2012-2013 Mazda3 (SKYACTIV 6 M/T)
2014-15 Mazda3 (Japan built 6 MIT) with VINs lower than JM1 BM******276367 (produced before July 1, 2015)
2014-16 Mazda3 (Mexico built 6 MIT) with VINs lower than 3MZBM******253322 (produced before August 31 ,
2015)
2013-2016 CX-5 (6 MIT) with VINs lower than JM3KE******686295 (produced before July 1, 2015)
2014-2016 Mazda6 (6 MIT) with VINs lower than JM1 GJ******440069 (produced before July 1, 2015)
Wow, man that was super helpful! I didn't know there was a TSB issued and it looks like my car is in there, in between the first and second modification. I haven't seen any kind of hard shifting or vibration so I hope that mine does not become affected by it. But I prefer to know about these things in advance so I can get my head wrapped around what to do. Thanks for posting!
No problem, hopefully that wasn't too much rambling in one post! My cars have 123k (CX-5) and 82k miles (3), and both still shift like butter, so we'll see!
