The weight transfer is basically necessary for cornering. The more cornering force, the more weight transfer there is going to be. Basically the weight transfer from one side to the other counter acts the roll created. There are things which you can do to lower the amount of weight transfer for a given cornering force, but springs and sway bars make no difference.
To pit it simply, if you picture a car just sitting there not moving. Now imagine the ground pushing from left to right on the bottom of the tires. This will cause the car to roll around the CG. That force is applied at the ground and the CG is above the ground. This will give an overall torque to the chassis. As everyone knows every force has an equal and opposite force. Well the opposite force to the car rolling is the weight transfer on the tires. The left tires will have more load than the right. This difference in the load causes the equal and opposite torque on the chassis through the CG.
The higher the side load (cornering) on the tires the more weight transfer is required to oppose it. Also from this the springs and sway bars have nothing to do with the weight transfer of the car. They will effect how much roll the car will see, but now the loading.
So it isn't really a matter of the weight transfer being beneficial, it is just necessary. Not sure if that answers your question.
If I understand you correctly, you're trying to say that ultimate grip is sometimes sacrificed for better handling balance, which results in a faster car. Springs/bars balance the front and rear axle's grip by making one axle transfer more weight than the other, but they do not change the total amount of weight transfer for the whole car.
Edit: what doesn't make sense is your statement " for a particular car you need a certain amount of weight transfer to achieve the maximum cornering for the tires" when, in fact, less weight transfer is better provided that the balance of the car isn't upset.
