thunder said:I think the safest option would be to use the Perrin intake. It's the shortest intake out there and it has been well tested... at least they did R&D on it.
Probably b/c it's a little too short...505zoom said:I'd wait until they fix the stalling issues with that intake, IMO. There are still people stalling recirculating.
TeeTeeSpeed said:ok i have another question!! how come sometimes when i see in magazines, some people who have turbos, dont have any kind of intake on it? is it because theyre bigger turbos or something?
a small pipe is required just because of the room available, the inlet to the turbo (the velovity stack) is like 4 inches in diameter, and you have to place the filter to the dirvers side of the radiator, and the Spal fan because there just isn't enough room.mp5jeff said:if you get rid of the maf, i suggest running a filter straight onto the turbo...or even just a screen that blocks s***...i might do this myself someday here..
TeeTeeSpeed said:whats a standalone?
engine management that runs the motor...TeeTeeSpeed said:whats a standalone?
put a screen over the compressor housing inlet...just don't go driving through water puddles! even then the water shouldn't hurt it...but dirt and s*** like that might, but do you rally race? if not you should be safeRyanJayG said:a small pipe is required just because of the room available, the inlet to the turbo (the velovity stack) is like 4 inches in diameter, and you have to place the filter to the dirvers side of the radiator, and the Spal fan because there just isn't enough room.
