DiscreetSpeed said:i had none..just happened
Welcome to the club Discreet. Sorry to hear about it.
mspdfreak said:Yep, it's called branding. It sells cars.
Well, I know that, of course, but that doesn't mean the car is built for racing, which it clearly is not. I guarantee you don't see stock MSPs on the racing circuit.97Protegedx said:I thought that Mazdaspeed was a racing division of Mazda. I think it goes something like this. Mazdaspeed is Mazda's in-house race and street car tuning arm and is highly involved in both amateur and professional motorsports.
Hmmmm, I think I saw racing in threre. (scratch)
mspdfreak said:Well, I know that, of course, but that doesn't mean the car is built for racing, which it clearly is not. I guarantee you don't see stock MSPs on the racing circuit.
goku4658 said:these threads ******* scare me
wicked said:and this is why I pulled my LSD out,and re-welded it,and replaced the clutch with a stage 3 hybrib SPEC.
BEFORE it became a issue.
goku4658 said:did you go to a shop to get it welded?
mspHtown said:i was under the impression that the lsd cracks from the inside out meaning that rewelding it before it broke would only serve as a band-aid?
TX Speed Demon said:Me too. Noticed it after I installed the AWR Front Motor Mount. Sounds like two pipes hitting each other. I pulled out all my FMIC pipes, wrapped any areas that looked like they were hitting something and reinstalled. No difference. I'm going to mark my front motor mount, drive around and see if it is loose (if markings don't line up).
If it's not a loose front one I think it is a torn rear one. My clutch still grabs strong, doesn't slip. There doesn't seem to be any corrolation to the sound and turning/power, it only happens when I engage first gear, or sometimes in second if I let the rpms drop close to 1000. I've checked everything else I can think of.
I'm going to take JDM Sam and LinuxRacr for a ride tonight to get their opinions. If we get this figured out I'll post back up.
agreed.wicked said:no worning,when it snaps it snaps.
mspHtown said:you guys figure anything out?
tytanium said:do you like your SPEC s3? I ordered the s2 (debated on the s2+ but didnt see my car ever seeing that kind of power). Is is fairly streetable?
