mspHtown said:
you guys figure anything out?
I still haven't replaced my rear motor mount, but last weekend I replaced my transmission fluid. Since then I haven't been able to duplicate the sound at all. Before changing the fluid I could do it anytime I shifted into first if I tried.
I honestly didn't think this would do anything for the previously mentioned problem. But I'm at 47K miles on the stock fluid and a friend of mine just blew the transmission (every gear) of his MSP due to low fluid. So I figured it was time to get some new stuff in there. I used Mobile 1 snythetic 75W90, 2.8 quarts (was 8$ a qt at Autozone). I should have, but didn't measure how much of the old stuff came out of the tranny.
Like I said, I have not been able to duplicate the banging noise since changing the fluid. It could be coincidence. It could be I was low on fluid and somehow that made the noise inside the tranny. Could be the synthetic fluid makes smoother engagement which leads to less vibration so the sound just doesn't happen now. I don't know, but it's worth checking out, especially if you're still running the stock fluid.
BTW, the two bolts (under and in front) on the tranny are 23mm. And if you use a funnel with a long hose you can put the hose in the front hole and fill it with fluid from the engine compartment. Takes a while for gravity to get all the oil in there though.
tiwing said:
Only thing I can think of re: the banging of pipes sound is that the tranny mount for the exhaust on aftermarket exhausts wasn't replaced - pic of where it should be. with stock motor mounts or softer aftermarket mounts there will be a lot of movement at this spot and it might more around that much.
Plus, if it's not attached here all the flex is being absorbed by the exhaust manifold / turbo manifold which could be a reason for cracked manifolds... Check this anyhow, and if you don't have a bracket/support there, go get one put in.
pic of bracket
Yeah that bracket broke when I had the stock exhaust in. My Apex one is much lighter, with a flex hose section, and with tighter exhaust hangers too. I also bent the hangers welded onto the car to hold the kartboy hangers tighter, now there's very little movement there at all. All this was done a few months ago and the car still had the problem. I did check underneath the car too. Initially I thought it was the exhaust hitting the crossmember or the undercarriage. I checked it all out but couldn't find any scratches or dents, and padded the crossmember just in case.
Still had the problem.
genius said:
Another banging of the pipes could also be your hardpipes hitting the Master Brake Cylinder. A lot of people have associated it with clutch chatter.
This isn't it. I've had that issue previously when I first installed my highboost fmic last year. I fixed it, but just to be sure I also padded this area.
