Just noticed that at warm idle my oil pressure hangs around 10psi and frequently drops to about 5psi. Oil pressure appears to be normal on cold starts and cruisin, but looks to be a bit low on warm idle. Am I too low?
you guy are fine at idle oil is always low especially on newer cars did some research a while back for oil pressure sensor some sensors dont go off till 3psi but by that point your engine is toast and most after market sensors like the vdo oils sensor for saab goes off at 7psi but youll be seeing your engine oil light flickering.. hope that helps
