Greetings - Just looking for some advice.
Have a 2007 CX9 GT with 210k miles (original owner). Its been a reasonably good car for us. An issue developed with getting a low pressure warning light after warm up (10 - 15 minutes). Changed oil & filter, but the problem remained. Took the car to my mechanic and we replaced the pressure sender due to the old one leaking a bit and thinking it might be the cause, but the low pressure warning still comes on after warm up. Mechanic took another look before a deep dive and says that between 2k & 3k rpms the engine is making a knocking noise. Now concerned it could be a rod bearing or something similar causing the low oil pressure and is hesitant to recommend doing anything because of the cost vs. value of the car. Any older CX9 owners with the 3.5 V6 faced a similar sounding problem? Thoughts?
