Low Tire Pressure Light On But Pressures Normal! Why? 2018 CX-5
Be as skeptical as you want, but there are a plethora of tools to monitor function, reset and perform battery checks on the TPMS.
I stand corrected. Skepticism removed.
  • Activate and relearn all known 315 MHz and 433 MHz sensors (OE or Aftermarket)
  • Displays all sensor data in seconds, including sensor ID, tire pressure, tire temperature, and battery status
  • Manual input ID, duplicate ID, automatic create ID, sensor position change, and modify ID, functions
  • Activates, diagnoses and reads 100% of all OE and aftermarket TPMS sensors
  • Extensive 98% vehicle coverage including Domestic, Asian, and European
That last part, works with 100% of sensors but only 98% of vehicles? What of the remaining 2%? It works with all possible sensors but not that 2%?
Anyways, thanks for the info.
Maybe that 2% includes the gen 1 CX-5's that work based on wheel speed? :D
