Okay, here's the deal, from what I gather: The system actually IS VICS, and called such, though it operates in such a way that as engine RPM increases/decreases, and load accordingly, the flaps open in gradiants, rather than being a digital operation (1/0, on or off), as is the USDM version of VICS. Also, the black box on top of the plenum, as seen in this picture:
Is the vacuum reserve, used for activation of these vac solenoids. This is due to the fact that when this manifold was designed, the reserve was not only not built into the manifold, as it was in USDM versions of the manifold that had VICS, but the design was an early-stage production model that they didn't change later down the line. Remember that they had the Familia Sport20 back in 1998 ('99 YM), and that was the introduction of the VICS system for the F series.
Durring this pre-production time, several documents were released referring to this technology as VICS _or_ VRIS, as well as VIRC, VRCS, presumibly as it went through it's various production stages.
Thanks for the clarification, which made me go back to researching it again, and proved that it was, in fact, called VICS after production. =) The documents I had read about it many, many moons ago proved to be incorrect (I'd like to find some of them again, which I'm trying to do), but Mazda Pre-release white papers aren't a good source for information, as they aren't indicitive of the final production systems.
The lesson: Always keep up to date, even if you think you don't have to.
