Talking about your cooling solution brings up something I've been fighting since day 1.
My system pressurizes just fine - and now that it's 100 degrees outside - every time I come to a rest (traffic, stop lights, etc) after running for a good bit - the overflow pukes coolant from the cap (the reservoir overfills essentially). I noticed something odd though - a trail of coolant that's been burned onto the radiator - and it's coming from the top spigot (return) of the radiator. After closer inspection - it's got a crack all around the neck of the radiator (gotta love plastic rad's.....right?).
I'm now researching a new coolant solution that will utilize an aluminum radiator of the correct sizing - and possibly relocating the overflow tank, in large, because of the turbo components that are soon to be installed.
suggestions on radiator? I don't want to bit from your research - but man....it's mainly your fault I did this swap. I blame you implicitly! (eyeballs)
Anyways - boost is otw. 8psi to start, megasquirt pnp for the KL is almost bought and paid for (150 left on payoff). Gonna be a nice show once I get all that dialed in...
