Lewis7789 MS6 GT build thread
Video from May 5th at Mid-Ohio. Once again, a huge thanks to WillD for being an epic instructor and for the GoPro video.
First lap was taking it easy to get some heat into the slicks, skip to the middle for hot-ish laps. Critiques are more than welcome! I keep turning in way too early on the right hander after the back straight and I need to use the whole track.
You're looking pretty good and driving smooth. You should now try adding more speed as you get used to the awesome grip of the slicks.
Yeah, I wasn't carry much speed at all. I never even really got to use the brakes either... I'm a slow learner. haha
Mid-Ohio is a very technical and busy track, so it isn't easy to learn. It's especially hard learning the entire track at once. There are so many things running through your mind. The next track day you do there, try to pick out the turns you have the most trouble with and really focus on them.
Roger that. I paid my deposit for July 7th with AutoInterests at Mid-Ohio so I'll get some more seat time and work more on my lines, then will be able to add more speed with confidence.
You are not a slow learner at all. In 2 sessions you were on the correct line and you were driving smoothly from the first turn of the wheel, now it's just fine tuning things and getting more seat time.
Honest opinions needed. Yay or Nay for the new plate?
image.plate
I'm already too pretty. I don't need any dudes hitting on me...
