fishdonotbounce
Registered Zombie
- 08.5 CWP Speed3
I think gunmetal if you can do some other pieces in the same color. Either way I can't wait to see this thing get up and running!
I vote crinkle black valve covers with the raised lettering polished aluminum. Such a nice offset for a silver car.
you have to do heavy coats with wrinkle paint lol its ****** easy
all you do is prep the valve cover like normal, spray ONE heavy coat on the valve cover, make sure u get everything on the first coat...you cant recoat wrinkle
then what i did was stuck it in the oven at the lowest setting for like 20 mins...came out perfect, nice even wrinkles
yea you have to use heavy coats to get the wrinkle effect. lol
Looking good so far!
Well the company I bought the motor from has a 30 day warranty but has to be installed by an ASE certified tech and with 30 days of receiving the motor. So the worst case scenario the motor is trash then I'll just have to swap the FS-DE back in and get the KL-ZE repaired. But honestly, I'm not too worried about it. I've seen a lot of other KL-ZE's with light surface rust just like mine on ProbeTalk and all those cats said it's fine, no big deal. I also have to bare in mind this motor could be as old as 1993. Like I said, I'm an optimist.
And Phen, that's kinda the reason why I bought the motor from eBay too, because they wouldn't want to ship out bad motors and receive negative feedback whereas if I bought one direct they might sell me a more beat up motor.
I'm going to remove the intake manifold, the oil pan and the back valve cover tonight after work and put up more pics. I'm not expecting anything bad since the first head looks really clean. Just those nasty spark plugs scared me.
ps- Phen with the post count of 7,777
The curve necks have the KL-101 cams, same as the USDM KL-DE, only the straight necks have the aggressive KL-31 cams. It's a JDM motor, I'm pretty much 100% positive.
mini-udate;
I got intake mani off and the fuel rail removed. I knife edged the mani and blew it out really well to get rid off the metal particles. I removed the vacuum lines and masked everything off really well. I cleaned up the TB (it will get hour-glassed after paint. I ran out of time and wanted to get as much painted before it got too cold out) and masked it off and ready for paint. I picked up some new valve cover gaskets at Autozone and put the oil pan back on with some black RTV. so both valve covers, throttle body and intake manifold are off and ready for primer then paint. I got the wrinkle black and the directions say 3 criss-crossed heavy coats, then bake it. And some silver for the IM. I'm doing the TB and VC's in wrinkle black and the IM in silver, should look pretty good.
I'm going to order the Outlaw spacers tomorrow so I can bolt up the IM and TB after paint. Then order the transmission in two weeks on the next payday.
Probably since these motors will bend valves if the timing belt breaks. But the timing belt scares me a little since Kevin never could get his 1.8l right. So with it looking like a low mileage car I might just start it and run it to break it in and see where I stand on what needs to be replaced and what I'm just throwing money at. Ya know? I don't want to change too much too the motor right away. I want to start it and run it for a little bit before going too mod crazy. Plus a timing belt can be done with the motor in the car still. I'm kinda on the fence about opening more of the motor up. I mostly just want to get it in the car and the wiring sorted and fire it up to make sure it at least fires up and runs well.
Did the first D16Y8 belt in the car... took 9 hours.
really? i just did my first one today and it took about 3 hours to replace the belt, water pump, idler, and adjust the valves
