LEDGlow 4pc. LED Interior Kit
kayla247
I purchased an LEDGlow 4pc. LED Interior Kit for my 2008 Mazda3 and I was hoping someone could please guide me to install it properly?
I would like to set-up my LEDGlow kit so that when I turn on my headlights, it will automatically turn on. I was told from staff that I need to purchase an eyelet connector. Would I have to modify any wiring by doing this? And they also recommended I test the post if it's hot or not with a multimeter... would I have to unplug the battery incase of electrical shock?
My fuse box that's located under the hood:
Here are the following instructions that they gave to install the LED Interior Kit to your fuse panel:
Connecting to a Fuse Panel
If you choose to wire the interior kit to an automatically switched ignition source in your vehicle, you must first locate the fuse for such a source. You may need your owner’s manual or the help of a mechanic.
Choose a fused source with at least a 10 amp fuse for the kit; anything less may blow the fuse with the kit installed and running.
Next, run the positive power wire (red) directly to a fuse slot in your vehicle’s fuse panel and insert it on one side of the fuse slot. * Make sure not to bridge the fuse with the wire or it will render the fuse useless in the event of a short circuit in your vehicle. You may also purchase a replacement fuse with accessory
wire attached to one side at an automotive parts store.
Finally the ground wire (black) may be connected to any ground source or any bare metal on the vehicle.
I realize the black wire needs to be grounded, but where does the red wire go, into the eyelet connector? Or does the black write also get connected to the eyelet connecter? Thank you for all your help in advance!!!
Connect the power wire ( Red ) to the fuses post. Like they told you crimp on an eyelet connector. Then ground the black wire to any ground nearby. To be safe disconnect your battery when installing. This is a good idea for someone who is new to electrical work. I'm sure if your careful and the lights are off then you shouldn't have a problem leaving the battery hooked up. Is that it for installation. Are there any additional relays or fuses you have to wire in with the kit or does it only have the 2 wires? I hope this helps. I am not to good with explaining things in writing but good luck.
