LED bulbs
medicnys
I'd like to know if anyone has found LED bulbs that work on Protege5. I've tried APC and Toucan they didn't work. Can anyone help? Thanks (yellowp5)
get out your user manual and flip to the back. look up anything about lights. it tells you the parts numbers for all the light bulbs in your car. hope that helps:)
he probably means they wont fit in the round hole in the light fixture, i had the same problem with mine, i wanted red led turn signals for the back to replace the amber ones, and all of them were to big around to fit in the opening in the lenses.
Mike
Thanks guys. The ones that I had gotten did fit but they did not function. I'm looking for some that will work in a Mazda.
If you're talking about the gauge LED's, I've read that the gauge uses a #74 and a #194 bulb. Two of each if I remember correctly.. I know it's been discussed here before.
