Leak in drivers f floor board
2010 Mazda 5
I noticed I have a fluid, brake or clutch, not water, on my floor mat. Looks like it is coming from the clutch area. Could the clutch or brake fluid leak there.?
Sent from my Nexus 5X using Tapatalk
We had 12 degrees Monday morning. I figured the seals/o-rings failed. But no it has not been flushed. Have 63k miles on it.
Okay . That's what I was afraid of... Most likely since the system have never been bled or flushed, all the water that was absorbed into the hydraulic fluid froze and the expanding freezing water and fluid pushed out past the weakest point. It might be possible that everything is still ok, and you can get away with fluid flush and bleed.
Anybody have a good set of instructions for replacing the clutch master cylinder?
Latest posts
