last few things before i start up!
That's how the stock setup is on every car made, after 86k miles my turbo didn't have very much oil residue in it. Get a catch can or stick a breather on it if you are paranoid, a breather may throw a P0171 as there will be a very slight vac leak.
I've had the breather setup for about 3 years and the light comes and goes, I have tested it using propane gas while watching the STFTs to find the leak.
ok, last one i think, going to start er up this weekend!!! :D
this one is attached to the fuel press regulator??
there are 3 hose ports;
1 going up top is to intake mani yes?
1 to side is going to fuel press regulator on fuel rail yes??
1 on bottom without a hose on.. i have no idea where it goes..
not even 100% on the first 2 connections, anyone can confirm?!@
thanks a ton!
where did it go originally??? i dont like blinding things lol.. trying to get as much back to oem as possible - my extensive mods list
The picture I posted on the last page clearly shows how the FP solenoid mounts. I relocated mine to the spare spot on the bracket where the VICS and VTCS are, just have to retape the harness for the wiring.
does not show "clearly" :X im wanting to start my car asap and this is one of a few things i have to finalize.. can we confirm somehow please?! :D
again im not even 100% its the FP solenoid, isnt it??
heres the pic again View attachment 204588
it's supposed to have a cap on the one end that doesn't have a line going to it if you look at hornsfan's picture. you can CLEARLY see the brown plug and the line going to the fpr.
You can almost see the brown plug, this is the stock configuration for the FPR solenoid. I can mail you a solenoid cap if you need one I have plenty.
