digitalslacker
- Protege5
That you can cram in a p5?
I had the car a whole two days before I swapped the front door speakers to some MB Quart 5x7's and three weeks later.... I think I need some larger front door speakers. I have a 2003.5 (i think thats what it is) with the factory sub and the fronts just arn't producing enough low end / mid bass to have an even halfway-decent soundstage. I was wondering how many people have made brackets to fit 6x9's?
I'm wondering how deep of a spacer I can get away with before I hit the plastic on the inside of the door panel. I will be cutting the outline of the speaker out (the lip on the inside) if I need the clearance, which I probably will.
6x9's off the factory HU probably won't preform that well, but nothing a LOC and a small amp won't fix... unless I find a good deal on a 2din dvd / nav player before I get around to doing this.
Thanks in advance!
P.S. -- I'll love you forever if you have installed pictures with the door panel off =)
Thanks in advance!
