Take your own advice and don't jump to conclusions about what I do and don't use... I have tuned a fair number of Haltech's and fixed a few Haltech installations as well. I'm well familiar with the E6X and F10 systems. I have not had experience with the E8. I have also tuned a few of the E-manage and others.
The E6X from what I remember and can see trying to double check against spec sheets etc can only fire in semi-sequntial firing which means it fires the same as wasted spark ignition... pair injectors firing at a time. Since you then have to fire every revolution instead of every other revolution you run out of duty cycle quickly (unless they are firing a bridged semi-sequential and firing every other rev but doing closed valve firing... which is a whole 'nother thing to discuss...). And from what I recall with the systems I worked with etc that was the case, and it's what I'm finding from spec sheets and the like I'm pulling up in some quick searches. Now if it's not, then show me where it says otherwise and I'll happily stand corrected. We had the same "issue" on the Microtech early on and had them correct it for us to get to full individual 4 channel sequential.
I also remember coming across it at some point, but will have to dig to verify it, about not running with a cam sensor, and if you do that there is no way in hell you can run sequential.
I also don't see any issue with either of the quotes you posted... we did 260 whp on a car with stock injectors... and I said simply that with a walbor and stock injectors I believe it to be safe/fine to go to 220+ whp... we were having leaning problems at the 260 that I wouldn't recommend.... so I don't understand your point in posting those quotes.
And yes, while I sell and advocate and prefer the Microtech, I've worked with every system on the market for the Protege, and know how to tune, install, and run all of them.
