Kasman vs. SR Cam gears
Yendor
Contributor
02 Protege ES
I know of the issue with the SR cam gears interfering with the cam position sensor with some work to them. Would the Kasman cam gears be any better? The cam gears are being paired with a FSH9 intake am and a Corksport exhaust cam.
I believe the Kasman and the SR Motorsport Cam gears have the same issue with the cam pickup points moving as you change the degree on the cam gear. Proper working gears the cam pickups shouldn't move. I know back in the day Tri-Point engineering had a good set, and I believe Focus on the other forum was putting together a group buy on cam gears. The cam gears he is innovating are supposed to basically be an exact replica of the Tri-point gears.
Some info on the FSH9 Cam.
There's a lot of info to be found if you search, but it's a lot to sift through.
Shoot. I replied to a post in another thread.(braindead
