With the return of warm weather my Kartboy shifter has started to squeak. I first installed it last September using high temp wheel bearing grease. Recently it has started to squeak, but only when the temperature is warm and the car has been driven long enough to get a good heat soak going. Last weekend I replaced the grease with synthetic brake caliper grease containing graphite. The action was very smooth but Monday afternoon the noise was back.
My next step will be to try silicone grease if I can locate a source. Does anyone know where I can buy some? Any other suggestions?
