^ Well said.
The bottleneck is up in the stock downpipe and racepipe. That's where the restrictions are. With that taken care of, there is no need to spend big bucks on the CBE part, since it flows better than the maximum exhaust discharge rate of the stock K04 turbo. If you upgrade the turbo to something bigger than stock, only then does an aftermarket full 3 inch CBE to match the dp/rp begin to make sense.
Welcome, OP, to the world of high pressure direct injection turbocharged and intercooled Mazda. You will really like your car. There is lots of help to be found here. The search function is your friend, but it is sometimes difficult to use. If you can't find what you are looking for, consider using Google and put the word "mazdas247" (without the quotes) first in your search terms. Google should take you to this board and give you a good list of threads and posts on your search terms.
