Ok I got the head all back on as well as both cams. I went ahead and replaced the timing belt and water pump. Got everything buttoned back up and running.
Car runs great now! I still have a broken exhaust flange on that elbow pipe between the two cats.
So what was interesting is we had marked everything before we took it off. Then we followed the book to ensure the timing was set. The exhaust cam was one tooth off! I think what happened was the timing belt got too loose, and yes it was very loose. And it caused the exhaust to jump a tooth. This then caused the exhaust valve on cyl 1 to not close fully which burnt the valve. Thoughts?
Also the car has an issue now. It feels like it surges a bit. Meaning when I am driving it feels like I am pushing and releasing the throttle even when I am holding it steady. What would cause this? Could my leak in the exhaust cause this? Or should I go try a different throttle body from the junk yard?
