Jackie chan
- Pro5
I got it! And it's so stupid!
I was going through as many pins on the ecu plug as I could. Verified that the cmp, ckp, both ignition coil circuits, both o2 sensor circuits, we're all good. Was getting pretty discouraged.
Decided to check the maf circuit, pin 88 which is light green/black. Go to maf sensor, there is no light green/black, hmm. Poke around a bit more, turns out the maf and tps use the same exact plug and I had them backwards. So stupid. But thank you to everyone that pitched in. And to pcb with the pages.
