Nah, you're alright. These cars are just quirky. Try running a good fuel cleaner thru the car. That always seems to help me. Double check all your vacuum hoses and tighten your intake clamps.
It had to be around 290 though, so I got around 25 MPG...not too shabby.
Unless you were really flogging it you've got a bit of a problem with that kind of mileage. Mine was that bad when my (only one, lol) O2 sensor had the wires chewed by rodents and was totally disconnected. I was getting a CEL, too, and it was running really rich in open loop mode.
Yea, you'd have to have a big exhaust leak at the flange or have a cracked manifold. I think you'd notice that...
There's supposed to be a check valve on that line but I don't see how that would make you run lean. The only problem you'll run into is that you'll have less "boost" available when you apply the brakes after keeping the throttle open.
Great news about the e-check, that means you have a year to figure out this P0171 thing, right?![]()
Is insufficient vacuum the same as having a vacuum leak?
Or, will the problem with this line only affect the brake booster, and not necessarily the intake side of the equation? It's not like the intake is pulling vacuum from the booster or anything, it's the opposite.
I didn't think 25 MPG (80% city/20% highway) was horrible?
Depends what you mean by "insufficient vacuum". When you open the throttle all the way the pressure in the intake manifold isn't that much lower than atmospheric pressure. In that case the check valve prevents the brake booster from sucking in any air. Maximum (negative) pressure is reached in the intake manifold when the throttle is closed. In that case air is pulled from the brake booster thus creating a vacuum. The check valve maintains that vacuum.
A vacuum leak occurs when unthrottled air enters the intake manifold which reduces the maximum negative pressure that can be achieved. This makes the car run lean and reduces the effectiveness of the brake booster (if it's a bad enough leak).
So "insufficient vacuum" at idle would be a good sign that you have a vacuum leak. If you already knew that please ignore this set of paragraphs
That's right, it shouldn't affect the intake. Unless there's a leak in the booster itself, but can that even happen?
Nice project!
Newbie here just signed up to ask a quick question, but hopefully will stick around for a while as I'm looking at purchasing a P5 when I get back from my UK trip in a few weeks. Anyway, the reason I'm posting is to ask what wheels are on the car? I've been looking at wheels that retain the factory size but still look good and those have caught my eye.
Thanks!
25 mpg isn't bad. The lowest I've ever gotten was 23 mpg and that was the dead of winter when I'd let the car warm up while I was cleaning off the ice/snow. Normally I'm around 30-32 and 36 or so on a trip. The best I've ever seen was 41 mpg on my way to NYC about 6 years and 70k miles ago. Didn't you leave that boost/vacuum gauge on the car? What's it reading at idle/driving/WOT?
