Couple few updates, and random pics I haven't gotten a chance to post in the last few days.
Wed night, w/the timing belt crap.
Make-shift way to "hold" the cams, didn't work...
Crank seal looked pretty good still.
All apart...
All together, few hrs later. LOL
Goodies!!! And, wouldn't you know that the key is the same on the locks on the car now! Could've just bought the new set and used the key to get these off. Ah well, it's only $20, and I'm sure I'll use the set of bolt outs again.
All the mounts just had inserts in them. I took them all out. Not sure on the front one though, it looks legit.
Exedy Stage 1 clutch...purdy!
Neighbor Kevin giving me a hand...
Evan brought me over his clutch tool, and it worked like a charm! Mounting the tranny up to the motor proved to be a 2 person job though, so I called Kevin over to help. lol After that, it was all downhill. Dropped the motor in, bolted it up, attatched the PS and AC and belt, tranny linkage and brake line, axles and LCA's, header to midpipe, ran the alternator and starter harness, installed the radiator and spliced in the fan plugs (guy cut mine off to wire in SPAL's) and tried to bolt the valve cover on, but realized in a previous parts store run, the dude forgot to ring me up for the gasket! He brought it out, and set it on the counter, but we must've left it sitting there when we picked everything up and moved to the register.
Tomorrow
should be the day. Realistically, all that's left to do is bolt up the intake manifold and valve cover, hook up heater core hoses (need to replace one), run the OCTOPUS of wires and vacuum lines, intake and battery, fill up all fluids, bleed clutch, and see what happens! Stay tuned!
