no worries i was just kinda busy at work at the time i wrote that. multitasking ftl
what will be interesting to see is how the itbs will perform to a single throttle as I will be able to just remove the throttles altogether and replace with silicone couplings and then put on a single throttle whenever I want to switch the layout. this way I can get direct back to back comparsion with very little to do to swap back and forth.
as for the benefits, I am hoping to have increased throttle response, a larger powerband and a higher peak power number compared to the stock BP FWD IM *if* I did everything right. With itbs it is pretty easy to go two steps back with minor changes so I try to document everything along the way and build several protos to get things right. the biggest lesson I have learned so far is to keep the length of the runner from the itb to the flange as long as possible compared to the runner from the itb to the plenum. Seems to make even more of a difference than runner diameter changes with the GSXR itbs. My guess is that this is because the "outlet" of the itb is not perfectly round due to the integrated injector mounting, and the airflow needs more space to get back on track, where as the other end or the "inlet" has a perfectly round diameter. I think if I spent some time porting the ITBS to make the "outlet" more circular I could diminish or eliminate this effect, but thats out of the cards for now.
