JDM-P5's Build Thread
you're going with different sized tires in the rear??
Yes, going with some more beefier rubber in the rear.
Since I'm running 215/35 in the front I'm going to try 225 or 235/35 or 40 in the rear. If it doesn't work out I have the hook up at the tire shop to do a swap to match everything.
Maybe the usual 225 or 235/35 or 40 front & rear.
The OEM is 215/45/18R for the front & the rear anyway so width isn't the issue. But the height difference front & rear shouldn't be too bad. Maybe if I keep it 35s all the way around and just run wider in the back I wonder if that will cause any problems?
I won't be tracking it nor will I be driving all crazy in it.
If I plan on doing a track day, the stockers would go back on for that.
During the winter the stock 18s will be installed.
Thoughts? Is the issue with the ECU/diff that much of an issue that it would cause problems? I'm not exactly running staggered wheels, just a slightly larger tire in the back.
you do understand that with AWD you need to run the same tire size on all 4 wheels right? you are just asking for problems if you don't. the ecu will see different wheel speeds and your rear diff will probably fry. also there is no point in running different size tires so why do it?
Hmmm, never thought about it like that.
Wonder why the WRX/EVOs run staggered set ups?
Guess I'll be making some changes. lol
i just did a quick search on that and even though they are staggered they use the same size tire, i believe it's just a different offset.
and even at that from what i've seen they dont' recommend it.
Hmmm...245/35/19 is what my tire guy just offered me.
I know Taylor was running 245/40/18. He rolled & pulled. I'll have to do the same plus some.
Taylors:
I of course want to be considerably lower than that though...
Thoughts on that set up for me?
Is Rhoadblock on 19s now? I would talk to him about wheel fitment on the MS6 if you are going for a nice aggressive stance. Even though he is now slammed, his car went through a series of phases from mild to his current form.
Definitly. Looks as if ya forgot to put bc's on the rear. But dam. Drop the rear to match and that baby look siick. Ha ha.
Liiiiiiiike thiiiiiiiis?
And of course a comparison shot:
LOL
Also, here's the shot w/the RX8 shift knob:
I need to find something to replace the gear map.
