James Barone Racing
Performance Aftermarket Parts & Accessories
JBR Oil Catch Can Kits
LINK TO PRODUCT PAGE
Details: JBR Stage 1 Oil Catch Can Kit.
During everyday engine operation, blow-by gases, as well as oil mist from the engines rotating components pass through the PCV valve and are routed back into the intake for the engine to burn off. However, some of that oil mist and other contaminates adhere to the intake and the valves. Over time a crust is formed reducing performance and potentially leading to a costly cleaning or repair. This is especially a problem for 2.3L DISI motor where there's no fuel passing over the valves to clean them. This is why an OCC is a must have for the Mazda 2.3L DISI community.
As PCV gases enter the catch can they disperse and flow through a series of four filter screens. As the gases flow through the screens, heavy oil and gunk sticks and lighter gases reach the outlet tube at the top. Accumulated oil and gunk naturally run off the filter screens and collect at the bottom of the tank. Throughout the life of the catch can, the filter media will never break down or need to be replaced like catch cans with mesh filter material. The net effect is blow-by gases, oil and other impurities do not have a chance to reach critical components of your engine.
Construction:
Lids Press-Formed from 304 stainless
Inlet & outlet fittings fabricated from straight 5/8" 304 stainless tubing
Can fabricated from 304 stainless and CNC machined components
Precision TIG welding on all components
Internal filters machined from 6061 perforated aluminum
1/4" NPT quick drain
Includes:
Oil Catch Can
60" of 5/8" reinforced vacuum hose for numerous mounting locations
Stainless steel hose clamps
Stainless steel mount hardware
Custom Mounting bracket
All the necessary fittings to get the job done right
Online installation instructions
Details: JBR Stage 2 Oil Catch Can Kit Includes a 1/2" Check Valve.
Details: JBR Oil Catch Can Check Valve.
So whats wrong with the factory PCV valve?
The short answer is nothing; as long as the car is stock and everything is properly maintained. But if you are running anything more than stock boost or would prefer to not have oily residue in your intake and crud building up on your valves, read on.
Since the PCV valve is the heart of the PCV system, lets start there. This thing is notorious for not being able to completely close to prevent boost from entering the crankcase, even when brand new. Add a few thousand miles worth of crud flowing back and forth through it and it the worse it gets. And the more boost you run, the greater the problem becomes.
The check valve included with the stage 2 OCC kit is designed to be closed 100% of the time unless vacuum is present. This check valve is oil, fuel and chemical resistant. It's constructed from solid brass, it has an incredibly low crack pressure and it's the largest check valve available so that normal flow isnt impeded.
Unfortunately the OEM check valve just can't close instantly under boost and therefore crankcase pressure and turbo spool times are increased. For higher boosting cars or those seeking the best possible performance out of their engine an OCC check valve is a must.
