I've got issues!!??!!
Jackie chan
Pro5
Ok guys, ive got a problem with my P5. When I start it up i get a weird whine. Its kinda like a belt squeel, but its not I dont think. Its quieter than a belt squeel and it is constant, where as belts tend to kind of pulsate. It's really annoying and I don't know what it is. I've tightened my outer accessory belt and had no luck. I'm gunna try to tighten the alternator belt but I cant find the "lock " bolt for it. The adjuster is easy to see, but i am having trouble finding the other one. If someone could post a pick or somethin' it would be greatly appreciated.
Thanks, -Ben
Thanks, -Ben
The Lock bolt for the Alternator is easy to access you'll see it it's right on the Middle usually it's usually a 12MM bolt justLossen it up enough but DO NOT TAKE IT OUT! because it's a pain to get back in and then pull your Alternator belt tighter . That should help fix the problem . while your at it just replace the Belt your belt is probably shot to!
Your welcome man no problem if you have any other question's about your Protege just message me through here or Pm me.
I think he's talking about the bolt for the pivot which you'll see if you look under he car its on the alt.
Thanks, but I figured it out. No more squeel and she purrs like a kitten. The belt is fine, I guess it musta stretched.
Did you access the pivot point from under the car ? I can reach the pivot point on mine, it's a 14mm btw, I cannot get enough power to break it free. Any suggestions ? I have been trying to get at it from the top.
Does anyone have a link to the proper point at where I need to place the jack stands. I have never had to lift a car this much or even get under one before. I just have delayed doing this for so long cause I felt uncomfortable with it
I adjusted mine from the top without removing anything. Loosened top bolt. Tightened bolt c as explained in the manual, tightened back up bolt b, or the top bolt. And all done
