Okay guys, I have a bit of an update. So I fixed my injector O ring... Before I begin, I jsut wanna say that I expected to have a few "wrinkles" to iron out, so I'm not pissed about any of this - the joys of having a new engine! I digress...
Anyway, so got the injector fixed, then went to start the car, and it would start, but then go WAY lean and die after about 5 secs. so, I tried about 20 times to start it, each time it ran progressively longer, and finally on like the 20th try it stayed running, and once warmed up my AFR's were righti n the normal range. Drove al lthe way home, and not a single hitch. Car drove liek a dream. This confirms my suspiscion on the O2 sensor. I' mthinking the heater in it went bad, since it won't read accurately until it's hot, right? So, all those times me cranking it got it just warm enough to work properly, and of course when It's running (hot starts are fine btw) then the exhaust heat had it warm enough to keep it running good. So, I'm replacing the O2 sensor tonight.
My AWR pan was leaking liek a sive (see other thread) so I took that stupid s*** Cometic gasket outta there and RTV'd it last night. Keep in mind that the whole time it leaked (only 1 day) the oil level was FULL the whole time. I topped it up. So anyways, I looked in my pan and my pickup has been hitting the bottom, even though I had to press in the screen on it to get it to fit the pan with thw AWR spacer, so basically there was only like 1/16" of an inch that oil could come into the pickup tube, which would explain my hot idle oil press of 17psi. (10 psi per 1000 RPM is required, so I was still good, but that's WAY too low for me) so after I cleaned my pan up, I took the AWR spacer off of the pickup and measured, and without the spacer (and with the screen now fixed so it's like normal) the pickup is still only 1/4" inch of the bottom of the pan. Why AWR includes the spacer is beyond me. That pickup sits WAY too low in the pan. Even now, it will still be submurged completely for 1" BELOW the L mark on my dipstick. So basically, even if I have NO OIL on my dipstick (who the **** would run it that low) my pickup would still be submurged. So, tonight the O2 sensor goes in, and I'll fill it back up with oil and try things out.
On a side note, Dana built another great engine. I pulled the fuse and cranked it first for about 20 secs to build oil pressure, then put the fuse in and it started right up after 2 cranks. (Just like normal!) It smelled like s*** while all the oil burnt off the pistons, etc and everything got seated in, but even now after only 250Km (about 175 mi) it's already starting to smooth out. The oil was full of microscopic particulates, as it should be, but no massive chunks of anything, so life is good!
