Norman@spool said:
As you may know our kit runs the BOV venting into the atmos, I think FM's runs a recirc setup.
Right, and FM owners don't complain about stalling much as far as I see...
Yes theoritically if you are dumping umetered air into the atmos the MAF does not take this into account and you should stall.
However we have run quite a few cars without any stalling issues venting into the atmosphere including spoolins car.
But you can't totally count spoolin's car because he's running a totally different engine management system.
So if this is actually true about atmos venting bov's then why do half of the people out there do not encounter any problems on the same exact car.
Well, most people who stall, the car just BARELY stalls...change a few slight variables (which automatically exsist between the different cars), and it can make or break the car stalling or not.
Also alot of the MSP guys run bov's venting into the atmos without any stalling issues.
True, but it's a different ECU.
Things we have noticed:
Most of the guys with the HKS have had more of a problem than the Greddy bov's
That's just one more reason that shows that it's probably the BOV.
Most people have had minute vacum leaks that have effected stalling and did not track the leak weeks or months later.
For some freakish reason we have noticed that some peoples stalling problems just dissapeared like deep stated.
The ECU learns over time.
Like I said to Terry last night...I'm not guaranteeing that I'm right in my thinking that the BOV to atmosphere is the cause of a lot of the stalls, but what I'm saying is this: We can debate back and forth all day long about whether it's significant enough to make it stall or not. In the end, my logic is that whether it effects it or not, it's not going to hurt to recirculate it anyway. To update the kits to recirculate would probably take an hour to redesign, and it would probably cost about $2 per kit to do. So I see no reason not to go ahead and make it standard in the kit. I'd really urge you to do that. On top of that, I feel it would help fix the issue if the BOV is leaky to begin with (if the spring was too loose)...since it would "leak" right back into the compressor anyway. Again, no reason not to do it. And while you're redesigning the intake, I'd really like to see it bend down (since there is a good amount of free space between the block/tranny and the IC pipe) to get some slightly cooler air.
Let me know what you guys think!
