Is there a way to reduce steering effort?
erhayes
2025 CX-5 Turbo
Contributor
Traded my 2014 CX5 touring for a 2021 CX5 GTR. The steering effort seems to be quite a bit higher in the GTR. Is there a way to reduce the steering effort? I did check and reset my tire pressure to the recommended 35 pasig. Thank you Ed
I had a 2013 and a 2016. To me my 2020 (all GTs) is lighter in steering that the other two. I thought it might have to do with lane departure having "room" to shake the wheel? Do you have lane departure turned on?
Upvote 0
If it takes noticeable effort to turn your steering wheel, you should take it in and have it checked under warranty.
Upvote 0
Reading the service manual at http://www.mcx5.org/ it says that the Caster angle has been increased. But I am not sure at what point the change was made. But almost assuredly this was done between 2014 and 2021. More Caster in front increases the tendency of a vehicle to "self center" the steering wheel when in motion. Perhaps this is what you're experiencing?
Upvote 0
I will check out the Lane holding feature. The steering effort is not excessive but, just seems a bit heaver than I reeber the 2014 cx5
Upvote 0
The steering in my 2019 GTR is much heavier than it was in my 2010 Mazda 3, but I just got used to it. Now when I drive my wife's Camry I feel like the steering is way too easy!
Upvote 0
You could try increasing tire PSI to 38. A higher tire pressure should make the steering wheel easier to turn. But I would second what @Sig cx-5 suggested and bring the car to the dealer to have them take a look and ensure that everything is working properly.
Upvote 0
The lane hold feature has no impact on steering feel, unless it senses you drifting over the line. My Lexus will stiffen up the steering wheel when I put it in Sport mode. Maybe Mazda makes it stiffer by default to make you feel more engaged.
Upvote 0
No comments?
Steering too difficult Eddie? Maybe you need to hit the gym and bulk up a little. I mean , you're what, a mere 80 years old. LOL. You must be the senior member here. I question whether I'll see 80. More power to ya. Congrats on your new ride. Jmaz
Upvote 0
Very odd as I test drove a 2021 CX-5 turbo about two weeks ago and compared to my 2014 CX-5, found the steering to be much lighter.
I would get it checked out.
Upvote 0
PS. I'm 83 this month and I go to an AQUA fitness/Aerobics class three times a week so I am not arm weak. I traded my 2014 and drove my GTR home and noticed it seems to require a bit more steering effort. Not uncomfortable but, I was surprised. The GTR does have a "Sport" setting which changes the AT shift points and the throttle sensitivity but, not sure about steering effort.
Upvote 0
Could just be the difference between the "worn in" tires on your 2014 and the brand new tires on your new ride.
Upvote 1
Solution
It might be the tires. I noticed a different steering feel when I got new tires last summer. They're barely broken in so the steering is still stiffer somehow. It's more directional, almost twitchy.
Upvote 2
I did go from a 17" 65 series to a 19" 55 series which is more rubber on the road. Ed
That is not likely true. Both tires are 225mm section width. Any difference would be one or 2 tenths of an inch.
Since the suspension has very few adjustments, and the car is designed to have high steering feedback, you have 2 options; check and raise your tire pressure to the max pressure allowed on the sidewall, or trade cars.
Upvote 0
He could also change to a set of tires with a harder rubber compound, or swap to 6.5" wide wheels. No need to jump straight to trading cars, lol.
Upvote 0
Did you try turning on lane assist/shaking of steering wheel at high level when you depart the lane?
Upvote 0
