Been having an issue where, every once in a while, it'll take a lot more cranks than usual to start.
Then, in the past couple of days, I've noticed it will sometimes fire up and then immediately die – but if I retry immediately, key to Acc or Off and then back to Start, it fires right up with no issue.
Both scenarios seem to occur on warm starts, e.g. when the car has been sitting for like 1-2 hours. Haven't seen it happen on a cold or hot start.
No CEL so far. The car used to stumble very slightly on heavy throttle applications, esp. in the upper half of the rev range, but that seems to have stopped on its own. There's a very mild vibration in the cabin at idle. Other than that, the engine revs and pulls smoothly and returns good fuel economy (21-25 mpg in mixed use, including lots of stop-and-go and some lead-footed driving).
Thoughts on what to check? Anyone else had these issues?
