interchangable parts between sedan and p5?
just got into an accident, broke my passenger side headlight, front bumper, fender and bended hood. are any of these parts interchangable between sedan and p5? thanks in advance!
yes all interchangeable... except headlights unless you want to do some wiring but they will bolt on.
The headlights while the outer diameters are the same exact thing, the inside is different as the P5 has a separate high and low beam section and sedan comes with one single reflector using a sinlge H4 HI/LO beam bulb.
I put sedan lights on my P5 before I sold it, looked fine. Search my profile for a thread I made about the topic, you'll find the wiring instructions and everything in there.
One thing to keep in mind is that some fenders (2002.5+) have holes for the side markers, while earlier ones won't. So get one that matches yours. Also, the bumper cover is different between the P5 and the sedan. They mount up fine, but do have a totally different look to them. Also 1999 and 2000 sedan parts won't fit at all as the front end is different.
^Yep, 5 bolt proteges, except the MSP and MP3 use the same brake parts. I believe the rears are also the same, but don't quote me on that.
All 1999 to 2003 proteges also use the same front doors, but the rear doors are different between the sedan and wagon.
