a lot. plan on spending 650-850.00 on cams.
stage 3? how do they sound??MegaCycle cost me $700 for the Stage 3 with cores.
contact info on those?
Will megacyclecam custom grind cams to the integral stage 3 specs
Anyone know the specs to the Integral stage 1, 2, and 2.5 cams? Their website no longer works.
dont know stage 1 but heres the rest.
stage 2
seat duration(.014")-268 degrees
seat duration +.003"-261.4 degrees
.050" duration-227.9 degrees
gross cam lift-.375"(9.52mm)
stage 3
seat duration(.014")- 272 degrees
seat duration +.003"- 265.4 degrees
.050" dyration-232.2 degrees
gross cam lift- .385"(9.78mm)
Anyone ever calculate the LSA on the 2.5 N/A cams? the spec sheet doesn't give enough info... at least for my knowledge base
Care to explain what these number mean?
