Intake Manifold Install Question/Help!
RallyeRedSi
2008 Civic Si
What is this plug supposed to be plugged into, or do i have to cover it?
With the 626 mani. you just leave them as they are. I put little caps over mine bacause you don't need them anymore. Just don't unplug the electrical connector or you will most likely throw a CEL. Do that with both the Green and White plugged ones. One is for the VTCS and one is for the VICS. Here's what I did...
since you have no butterflies i wouldnt think it matters. they just actuate the butterflies. since theres none i cant see how it would matter unless they open up at a certain time then u might get a leak since its not a loop anymore. if u dont need em i would just plug both ends on both.
