installing a oil pressure guage on my msp?
i am pretty sure that if you you are looking from under your car. look up at the oil filter. off to the left about three in. you should see it. it is the thing with the wires coming off of it.
There are two things that look like that. It's the one with a green wire and a white plug.
I'm thinking about getting an electrical autometer oil pressure gauge. Does it come with a new sensor, or does it utilize the factory one?
Remove the old one, install a "T" fitting in the hole and put the stock one on one side and the new one on the other. This is also a way to get oil to a turbo.
i just used the stock sensor....
disconnected the wire and plugged in the gauge wire.
i was thinking of putting both of them on there(wires) to see if both would work? oh well
I was thinking of doing the same thing. What does your oil pressure read with the stock sending unit? I think hooking up both wires to the same sender would work since voltage in parallel is equal.
umm i dont remember i think at idle its like 25....ill see and get back. i know in the mornings when i first turn it on its like 75.
Re: Re: installing a oil pressure guage on my msp?
SOSPEED said:
Well since everyone else helped with the oil pressure gauge i have an idea for getting the oil filter off. I do it all the time. If the filter is on to tight just get some sandpaper and wrap it around the filter to use as an extra grip. It works every time. I dont even use an oil filter wrench anymore.
i have a old silicone fittin from my IC, i just slip that over the filter and it grips it real nice.. even when shes nice an snug it comes off without to much cursing.. I learned the hardway not to over tighten the filter (hand)
So when you guys say Tee-fitting are you refering to one of these or are we talking standard Tee?
i suppose you can use that there little space there.
but the one thats being used is a no s*** T design.
remember its BPT FITTINGS AND NOT NPT FITTINGS.
To whoever was thinking of running 2 wires from the stock sending unit....
The stock 'sending unit' is an on/off 12V trigger. If there is less than something like 7.5psi, it turns on the oil light in the dash. It does not have the capability to send fluctuating readings.
I don't understand why anyone would put a Tee in this location. It's such a pain to get to in the first place... it's difficult to do one connection much less 3!... VDO (and I would think autometer) makes a 0-80 psi sending unit with a low level warning contact. Affix the stock wire to the warning contact and the signal wire contact to the gauge. That's it.
I had the threads on the sending unit recut by the place I buy this stuff from, www.nhspeedometer.com. They're fairly easy to work with. If you have a die-cut set, you can do it yourself. The adapter works, too.
I use RTV sensor-safe silicon on the threads despite what anyone else says about tapered threads. (which is what sending units generally have) I've replaced enough senders to know it works better than not. Also, if it's your first time doing this kind of thing, having to deal with a leak and trying to tighten this thing in its location is a real b****. This makes the oil filter look super easy to get to and deal with... which I think it is but, that's me.
Good luck for anyone doing this. You'll most likely need to remove the arm that supports the intake to the block to get it done. Give yourself some time for this one.
To get the filter off, get a filter wrench for your 3/8 ratchet driver. Works like a charm. :)
All the other advice is about what i was gonna say.
I understand what all of you are trying to say but it isn't as bad as you are making it out to be.
That hole is where I tapped the oil for my turbo. I used a 2" pipe thread extension then a T fitting. One half went to the stock sender and the other half has an aeroquip line on it. There is a bracket that is removable with four bolts. It oppens up the entire thing.
"Keep the faith...If you book them they will come" - Jim Morrison
