Installed some TRS Clear Lenses Today...
Expected delivery for ground is going to be on the 31st (Friday). Just in time for this weekend.
Damn those look nice! I'm guessing you have to open up the headlight assembly to install these?
was going to come in here and see if anyone knew of this. stuff was going to look into it myself. looking to retrofit one of my other cars and stumbled across the cleer lenses.
Screwed together. Check the DIYs and they have all the info you need.
yea..i found some great ones on M3F. Now to gather the supplies like goo-gone and washers. BTW..did you reuse the sealant or apply more to put the housing back together. And did you dremel the little housing cut-off?
I reused the old sealant and so far no leaks. I've washed the car numerous times with a pressure washer and been through some crazy rain storms and they are still dry inside.
I did not dremel the inside, however I did paint the shield black.
It will be fine to use the old sealant. I switched the lens on mine too but with EVO8 lenses.
Did you do any washer mods?
What is the point of painting the shield black? Just for lens color when the lights are off? I dont want it to absorb any output.
I'm going to do the washer mod just for a little bit of flicker.
painting the inside blask is to cutdown on glare. some people will paint the opposite side of the shield any color for that flash of color when light are out. ive seen some red.
I finished. Use no washers for flicker. But theres a little bit from the lens spacer. Pics to follow. Reaimed already too. Very nice cutoff
Edit for pics:
^^ You'll get rid of even more glare if you cut that tab off of the shield.
Well..gotta crack back into one of the housings anyways. One didnt seal all the way and started to fog up when i washed the car. So I guess I'm going to cut that tap off and paint it flat.
