install fogs
08BlkMS3
Do you have to remove the bumper to install fogs on a 08 speed? I pulled back just a little bit of the fender well shield and cannot see much of anything. I am not sure if i need to pull the wheels and pull all the fender well out to get to the assembly of if they can only be installed from the front? Damn there is a lot of plastic on the front of this car, under, over, side, in, around and tons of tabs... Why couldent it be a crawl under your car, undo harness, replace bulb, replace harness, etc... Not remove half the plastics.
you dont have to, just jack up the front so you can get under, pull off the fender lining enough to get it out of the way,and the undercover if you really want. if you cant see, a flashlight is very handy. i didn't need to take off the wheels but if you think it shall be easier for you then by all means. it is a VERY tight space under there, but you can do it!
There is a small splash shield in front of the large one (that you drop of the oil) that is removed to access the fog lights. You can remove both for even easier access.
