Dat Slotege
- 2003.5 Mazdaspeed Protege
Bought an Injen Intake, is there any way to run this sucker with a blow off valve setup?
Did you only use the first pipe? I'm relocating my MAF and the intake hole is gonna be used for my front mount routing, so I was thinking about doing like you did.
id sell the injen and just buy a custom pipe if it was me. you could build a sri like i did for under $50 usd. doesnt need to be fancy if your not recirculating. i just use a 3" 45 pipe 18" long, a 3"-2.25" coupler a 3" filter and a random cutoff angle of 2.25" aluminum i was making my charge piping out of.
dirt cheap.
cant really see the small pipe down in there, but its there with a 2" coupler to the turbo. also relocated maf.
