mazda3zoom
- Sweetest Car Ever
does anyone know if the Injen CAI is available yet? (headbang)
mazda3zoom said:does anyone know if the Injen CAI is available yet? (headbang)
due to the # of high complaints with the 6 croud(Constant CEL) they will be doing extencive testing to prevent that from happening again.Loose said:I heard that rumor but when I called around I was told that either the distributors didn't get them yet or they were on back order. I tried 3-5 diffrent places and no luck. There is however apart number so there is hope.
Doesn't the 6i motor run richer than the 3 motor? Could this diffrence be the cause of the CEL's w/ the intake?crossbow said:I'm almost certain the 3 will have the same problem with check engine lights that the 6 did. Same engine as the 6i.
There have been two Fuel Trim too Lean Cel's on the 3 forums, but no more then that...yet. The way I'd put it...if your modding your car, be prepared to deal with consequences, otherwise don't mod it.
crossbow......you sure know how to make a newbie nervous..crossbow said:The way I'd put it...if your modding your car, be prepared to deal with consequences, otherwise don't mod it.
